The SR598 Flat Panel TV Cart has been redesigned to include all of the features you may need, making it perfect for any application. Mobility, appealing design, display height adjustment, pre-assembled base and UL certification ensure quick assembly while providing a ridged, but attractive, structure that fits into any decor. The 4" castors make it easy to move from room to room while the UL certification ensures you that it can be done with safety in mind.
Designed to meet ULĀ® certifications, the SR598 incorporates safety and security, ensuring you get the job done correctly.
Additional Features
- Display can be located anywhere along the column for perfect viewing height (up to 60" at center)
- Integrated cable management protects, contains and conceals cables for a clean, professional installation
- Maneuvers easily on 4" (102mm) swivel casters, two locking
- Pre-assembled base provides rigidity, stability and quick assembly
- Textured black powder coat finish helps hide finger prints and dust
- Open frame display adaptor helps prevent display input interference
- Optional ACC-MS component shelf can be positioned anywhere along either column by simply lifting and repositioning
- Universal mount fits displays with mounting patterns from 200 x 200mm up to 900 x 600mm
Plumb Adjustment
5 degrees of negative adjustment keeps even the heaviest of displays level
Open Frame Adaptor
Helps prevent display input interference
UL/CUL Certified
Provides the highest level of safety
Vertical Adjustment
Display and optional component shelf can be located anywhere along the column (up to 60" at center)
Component Placement
Optional metal shelf or laptop tray can be located anywhere along either column assembly
Welded Base
Provides rigidity, stability and quick assembly
Safe and Easy Maneuverability
4" (102mm) swivel casters meet UL/CUL requirements
- Peerless-AV SmartMount SR598 cart - for flat panel - black powder coat
- Product Type
- Cart
- 116.9 cm x 73.7 cm x 173.6 cm
- Tilt
- -5°
- 40.5 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 55"-98"
- VESA Mounting Interface
- Up to 900 x 600 mm, from 200 x 200 mm
- Max Mounting Pattern Size
- 981 x 608 mm
- Max Load Weight
- 136 kg
- Material
- Aluminium
- Black powder coat
- Wheels Qty
- 4
- 5-year warranty
- 116.9 cm
- 73.7 cm
- 173.6 cm
- 40.5 kg
- Material
- Aluminium
- Black powder coat
AV Furniture
- Cart
- Recommended Use
- Flat panel
- 981 x 608 mm
- Cable Management
- 55"-98"
- Tilt
- -5°
- Max Load Weight
- 136 kg
- Wheels Qty
- 4
- Locking casters, swivel adjustment, swivel casters, security hardware
- Limited warranty - 5 years
