Ideally suited for XXX large LCD and plasma screens, the SmartMount ST680P tilting wall mount allows you to mount even the very largest flat panel screens quickly and easily.
                Effortless adjustmentThe tilt feature of the Peerless SmartMount Universal Tilt Wall Mount allows for easy viewing angle adjustments, ensuring an optimal viewing experience from any position.
                Robust designDesigned to support flat panels ranging from 60" to 98", this mounting kit can hold up to 159 kg, making it a reliable choice for securing large screens.
                Comprehensive mounting solutionWith included fasteners, tilt bracket, and wall plate, the Peerless SmartMount Universal Tilt Wall Mount provides a comprehensive solution for installing your flat panel display, ensuring a hassle-free setup.
- Peerless SmartMount Universal Tilt Wall Mount ST680P mounting kit - for flat panel - black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, tilt bracket, fasteners
- 116 cm x 7.6 cm x 76.8 cm
- Adjustments
- Tilt
- 6.9 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 60"-98"
- Max Mounting Pattern Size
- 1061 x 650 mm
- Max Load Weight
- 159 kg
- Black
- 5-year warranty
- 116 cm
- 7.6 cm
- 76.8 cm
- 6.9 kg
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 1061 x 650 mm
- 60"-98"
- Adjustments
- Tilt
- Max Load Weight
- 159 kg
- Sorted-For-You
- Limited warranty - 5 years
