Peerless-AV SmartMount Universal Tilt Wall Mount for 60" to 95" Flat Panel Displays
Quicklinx: 7MVFWS00 Mfr#: ST680P
Type: Mounting kit
16 in stock
£123.34 ex VAT
£148.00 inc VAT
Ideally suited for XXX large LCD and plasma screens, the SmartMount ST680P tilting wall mount allows you to mount even the very largest flat panel screens quickly and easily.
Peerless SmartMount Universal Tilt Wall Mount ST680P - mounting kit - for flat panel
Mounting kit
Mounting Components
Wall plate, tilt bracket, fasteners
116 cm x 7.6 cm x 76.8 cm
Adjustments
Tilt
6.9 kg
Recommended Use
Flat panel
Recommended Display Size
60"-98"
Max Mounting Pattern Size
1061 x 650 mm
Max Load Weight
159 kg
5-year warranty
116 cm
7.6 cm
76.8 cm
6.9 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
1061 x 650 mm
60"-98"
Adjustments
Tilt
Max Load Weight
159 kg
Sorted-For-You
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
Stock Status: In stock
