Ideally suited for XXX large LCD and plasma screens, the SmartMount ST680P tilting wall mount allows you to mount even the very largest flat panel screens quickly and easily.
- Peerless SmartMount Universal Tilt Wall Mount ST680P mounting kit - for flat panel - black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, tilt bracket, fasteners
- 116 cm x 7.6 cm x 76.8 cm
- Adjustments
- Tilt
- 6.9 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 60"-98"
- Max Mounting Pattern Size
- 1061 x 650 mm
- Max Load Weight
- 159 kg
- Black
- 5-year warranty
- 116 cm
- 7.6 cm
- 76.8 cm
- 6.9 kg
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 1061 x 650 mm
- 60"-98"
- Adjustments
- Tilt
- Max Load Weight
- 159 kg
- Sorted-For-You
- Limited warranty - 5 years
