Peerless-AV SmartMount Universal Tilt Wall Mount for 46" to 90" Displays
Quicklinx: 7MVDWS00 Mfr#: ST670P
Type: Mounting kit
£152.11 ex VAT
£182.53 inc VAT
Ideally suited for XX large LCD and plasma screens, the SmartMount ST670P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
  • Versatile mounting
    The Peerless SmartMount Universal Tilt Wall Mount is designed with adjustable width and the innovative Incre-Lok feature, ensuring a perfect fit for flat panels ranging from 49"-90". This flexibility makes it an ideal choice for a wide array of TV sizes, enhancing your viewing experience by allowing for precise angle adjustments.
  • Durable design
    Crafted with scratch-resistant materials, this mounting kit is built to last, maintaining its aesthetic appeal and structural integrity even under heavy use. The robust construction supports flat panels up to 113.4 kg, ensuring your valuable electronics are securely mounted and protected.
  • Easy installation
    Equipped with the Sorted-For-You hardware pack and a comprehensive mounting components set, including a tilt bracket and wall plate, installation is streamlined. This user-friendly design simplifies the setup process, making it accessible to a broad range of users regardless of their technical expertise.
Peerless SmartMount Universal Tilt Wall Mount ST670P mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall plate, tilt bracket
95.9 cm x 7.9 cm x 52.4 cm
5.7 kg
Recommended Use
Flat panel
Recommended Display Size
49"-90"
VESA Mounting Interface
Up to 895 x 450 mm
Max Load Weight
113.4 kg
5-year warranty
95.9 cm
7.9 cm
52.4 cm
5.7 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Up to 895 x 450 mm
49"-90"
Max Load Weight
113.4 kg
Adjustable width, Sorted-For-You, scratch-resistant, Incre-Lok
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
