Peerless-AV SmartMount Universal Tilt Wall Mount for 37" to 75" Displays
Quicklinx: 7MVBWS00 Mfr#: ST650P
Type: Mounting kit
32 in stock
£64.91 ex VAT
£77.89 inc VAT
Ideally suited for large LCD and plasma screens, the SmartMount ST650P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless SmartMount Universal Tilt Wall Mount ST650P - mounting kit
Mounting kit - wall-mountable
Mounting Components
Bracket, tilt wall plate
79.4 cm x 13.7 cm x 42.9 cm
Adjustable Depth
6.7-13.7 cm
Tilt
-5° to 15°
Adjustments
Tilt
3.7 kg
Recommended Use
LCD display
Recommended Display Size
39"-75"
VESA Mounting Interface
700 x 400 mm
Max Mounting Pattern Size
750 x 405 mm
Max Load Weight
79 kg
5-year warranty
79.4 cm
13.7 cm
42.9 cm
Adjustable Depth
6.7-13.7 cm
3.7 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
700 x 400 mm
750 x 405 mm
39"-75"
Tilt
-5° to 15°
Adjustments
Tilt
Max Load Weight
79 kg
Finish
Powder coated
Sorted-For-You
Dimensions & Weight Details
84.3 cm x 27.2 cm x 7.5 cm / 4.7 kg
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
Price Range Ex VAT: 50 - 100
