Peerless-AV SmartMount Universal Tilt Wall Mount for 37" to 75" Displays
Quicklinx: 7MVBWS00 Mfr#: ST650P
Type: Mounting kit
More than 50 In Stock
£81.99 ex VAT
£98.38 inc VAT
Ideally suited for large LCD and plasma screens, the SmartMount ST650P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
  • Effortless adjustment
    With a tilt range of -5° to 15°, this wall mount allows for effortless viewing angle adjustments, ensuring the perfect view from anywhere in the room.
  • Versatile compatibility
    Designed to support LCD displays ranging from 39" to 75", this mount is a versatile solution for a wide range of sizes, accommodating virtually any room setup.
  • Robust design
    Featuring a powder-coated finish and a maximum load weight of 79 kg, this mounting kit is built for durability, ensuring your display stays securely in place.
  • Easy installation
    The Sorted-For-You feature simplifies the installation process, providing an organized, hassle-free setup to get your display mounted in no time.
Peerless SmartMount Universal Tilt Wall Mount ST650P mounting kit - for LCD display - black
Mounting kit - wall-mountable
Mounting Components
Bracket, tilt wall plate
79.4 cm x 13.7 cm x 42.9 cm
Adjustable Depth
6.7-13.7 cm
Tilt
-5° to 15°
Adjustments
Tilt
3.7 kg
Recommended Use
LCD display
Recommended Display Size
39"-75"
VESA Mounting Interface
700 x 400 mm
Max Mounting Pattern Size
750 x 405 mm
Max Load Weight
79 kg
5-year warranty
79.4 cm
13.7 cm
42.9 cm
Adjustable Depth
6.7-13.7 cm
3.7 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
700 x 400 mm
750 x 405 mm
39"-75"
Tilt
-5° to 15°
Adjustments
Tilt
Max Load Weight
79 kg
Finish
Powder coated
Sorted-For-You
Dimensions & Weight Details
84.3 cm x 27.2 cm x 7.5 cm / 4.7 kg
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
