Peerless-AV SmartMount Universal Tilt Wall Mount for 37" to 75" Displays
Quicklinx: 7MVBWS00 Mfr#: ST650P
Type: Mounting kit
More than 50 In Stock
£68.19 ex VAT
£81.82 inc VAT
Ideally suited for large LCD and plasma screens, the SmartMount ST650P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
  • Effortless adjustment
    With a tilt range of -5° to 15°, this wall mount allows for effortless viewing angle adjustments, ensuring the perfect view from anywhere in the room.
  • Versatile compatibility
    Designed to support LCD displays ranging from 39" to 75", this mount is a versatile solution for a wide range of sizes, accommodating virtually any room setup.
  • Robust design
    Featuring a powder-coated finish and a maximum load weight of 79 kg, this mounting kit is built for durability, ensuring your display stays securely in place.
  • Easy installation
    The Sorted-For-You feature simplifies the installation process, providing an organized, hassle-free setup to get your display mounted in no time.
Peerless SmartMount Universal Tilt Wall Mount ST650P mounting kit - for LCD display - black
Mounting kit - wall-mountable
Mounting Components
Bracket, tilt wall plate
79.4 cm x 13.7 cm x 42.9 cm
Adjustable Depth
6.7-13.7 cm
Tilt
-5° to 15°
Adjustments
Tilt
3.7 kg
Recommended Use
LCD display
Recommended Display Size
39"-75"
VESA Mounting Interface
700 x 400 mm
Max Mounting Pattern Size
750 x 405 mm
Max Load Weight
79 kg
5-year warranty
79.4 cm
13.7 cm
42.9 cm
Adjustable Depth
6.7-13.7 cm
3.7 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
700 x 400 mm
750 x 405 mm
39"-75"
Tilt
-5° to 15°
Adjustments
Tilt
Max Load Weight
79 kg
Finish
Powder coated
Sorted-For-You
Dimensions & Weight Details
84.3 cm x 27.2 cm x 7.5 cm / 4.7 kg
Limited warranty - 5 years
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 7MVB 047256
Condition: Damaged stock - Item is new but has packaging damage opened up as box was damaged
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £9.00
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Mounting kit
Brand: Peerless-AV
Stock Status: Used Stock
