Ideally suited for large LCD and plasma screens, the SmartMount ST650P tilting wall mount allows you to mount your LCD/plasma screen quickly and easily and tilt it forward/back for an improved viewing angle.
Effortless adjustment
With a tilt range of -5° to 15°, this wall mount allows for effortless viewing angle adjustments, ensuring the perfect view from anywhere in the room. -
Versatile compatibility
Designed to support LCD displays ranging from 39" to 75", this mount is a versatile solution for a wide range of sizes, accommodating virtually any room setup. -
Robust design
Featuring a powder-coated finish and a maximum load weight of 79 kg, this mounting kit is built for durability, ensuring your display stays securely in place. -
Easy installation
The Sorted-For-You feature simplifies the installation process, providing an organized, hassle-free setup to get your display mounted in no time.
 - Peerless SmartMount Universal Tilt Wall Mount ST650P mounting kit - for LCD display - black
- Product Type
 - Mounting kit - wall-mountable
- Mounting Components
 - Bracket, tilt wall plate
 - 79.4 cm x 13.7 cm x 42.9 cm
- Adjustable Depth
 - 6.7-13.7 cm
- Tilt
 - -5° to 15°
- Adjustments
 - Tilt
 - 3.7 kg
- Recommended Use
 - LCD display
- Recommended Display Size
 - 39"-75"
- VESA Mounting Interface
 - 700 x 400 mm
- Max Mounting Pattern Size
 - 750 x 405 mm
- Max Load Weight
 - 79 kg
 - Black
 - 5-year warranty
 - 79.4 cm
 - 13.7 cm
 - 42.9 cm
- Adjustable Depth
 - 6.7-13.7 cm
 - 3.7 kg
 - Black
AV Furniture
 - Mounting kit
- Recommended Use
 - LCD display
- Placing / Mounting
 - Wall-mountable
 - 700 x 400 mm
 - 750 x 405 mm
 - 39"-75"
- Tilt
 - -5° to 15°
- Adjustments
 - Tilt
- Max Load Weight
 - 79 kg
- Finish
 - Powder coated
 - Sorted-For-You
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
 - 84.3 cm x 27.2 cm x 7.5 cm / 4.7 kg
 - Limited warranty - 5 years
