Ideally suited for medium/large LCD screens, the SmartMount ST640P tilting mount allows you to mount your LCD screen quickly and easily. The tilt function allows you to angle the screen forward or back for an enhanced viewing angle.
- Peerless SmartMount Universal Tilt Wall Mount ST640P - mounting kit - for LCD display - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Bracket, tilt wall plate, security fasteners
- 56.2 cm x 47 cm x 14.5 cm
- 4.22 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 32"-60"
- VESA Mounting Interface
- 400 x 400 mm
- Max Mounting Pattern Size
- 458 x 449 mm
- Max Load Weight
- 68 kg
- Black
- 5-year warranty
- 56.2 cm
- 47 cm
- 14.5 cm
- 4.22 kg
- Black
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- 400 x 400 mm
- 458 x 449 mm
- 32"-60"
- Max Load Weight
- 68 kg
- Limited warranty - 5 years
