Peerless-AV SmartMount Universal Tilt Wall Mount for 22" to 40" Displays
Quicklinx: 7G5DWS00 Mfr#: ST632P/BK
Hurry, only 1 left in stock!
£36.00 ex VAT
£43.20 inc VAT
Ideally suited for medium LCD screens, the SmartMount ST632P tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
Medium sized screens are quick and easy to install with this pre-assembled mount. Just mount the wall plate to the wall, attach the wall plate to the flat panel screen and hook on the VESA compliant adapter plate to the wall plate. Its continuous one-touch tilt mechanism helps guide the screen to the ideal viewing angle with just a touch - no tools required.
Brand: Peerless-AV
