Peerless-AV SmartMount Universal Tilt Wall Mount
for 10" to 29" Displays
Peerless-AV SmartMount Universal Tilt Wall Mount for 10" to 29" Displays
Quicklinx: 7MV3WS00 Mfr#: ST630P
Type: Mounting kit
Hurry, only 2 left in stock!
£21.39 ex VAT
£25.66 inc VAT
Ideally suited for small LCD screens, the SmartMount ST630P tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
  • Effortless adjustment
    The tilt feature allows for easy viewing angle adjustments, ensuring an optimal viewing experience.
  • Durable design
    Crafted with scratch-resistant materials, this mount maintains its aesthetic appeal and ensures durability.
  • Versatile compatibility
    Supporting a wide range of display sizes from 10"-29" and compatible with flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, this mount is designed for a variety of LCD displays.
  • Easy installation
    The wall-mountable design, complete with an adapter plate and tilt wall mount components, offers a straightforward setup process.
  • Robust support
    Capable of holding up to 36.3 kg, this mounting kit provides reliable support for your LCD display, ensuring safety and stability.
Peerless SmartMount Universal Tilt Wall Mount ST630P mounting kit - for LCD display - black
Mounting kit - wall-mountable
Mounting Components
Adapter plate, tilt wall mount
15.9 cm x 15.9 cm x 3.8 cm
Adjustments
Tilt
1 kg
Recommended Use
LCD display
Recommended Display Size
10"-29"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.3 kg
5-year warranty
15.9 cm
15.9 cm
3.8 cm
1 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
10"-29"
Adjustments
Tilt
Max Load Weight
36.3 kg
Scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
