Ideally suited for small LCD screens, the SmartMount SP730P pivoting wall mount gives you a wide range of screen adjustment to obtain a better viewing angle. The SP730P allows you to tilt your screen forward or back, pan left or right and even extend your flat panel screen away from the wall.
Versatile design
The Peerless SmartMount Pivot Wall Mount is designed with tilt and swivel capabilities, offering flexible viewing angles for an optimal viewing experience. -
Durable construction
Crafted from aluminum, this mounting kit ensures sturdy and reliable support for LCD displays, making it a lasting addition to any setup. -
Easy installation
With its wall-mountable design and included pivot wall mount, setting up your LCD display is straightforward, allowing for seamless integration into your space.
- Peerless SmartMount Pivot Wall Mount SP730P mounting kit - Tilt & Swivel - for LCD display - black
- Product Type
- Mounting kit (Tilt & Swivel) - wall-mountable
- Mounting Components
- Pivot wall mount
- 80 g
- Recommended Use
- LCD display
- Recommended Display Size
- 10"-29"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 11.3 kg
- Material
- Anodised aluminium
- Black
- 5-year warranty
- 80 g
- Material
- Black
AV Furniture
- Mounting kit
- Pivot wall mount
- Design
- Tilt & Swivel
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- 10"-29"
- Max Load Weight
- 11.3 kg
- Limited warranty - 5 years
