Peerless-AV SmartMount Universal Pivot Wall Mount For 10"- 29" Displays
Quicklinx: 7MVGWS00 Mfr#: SP730P
Type: Mounting kit
£56.58 ex VAT
£67.89 inc VAT
Ideally suited for small LCD screens, the SmartMount SP730P pivoting wall mount gives you a wide range of screen adjustment to obtain a better viewing angle. The SP730P allows you to tilt your screen forward or back, pan left or right and even extend your flat panel screen away from the wall.
  • Versatile design
    The Peerless SmartMount Pivot Wall Mount is designed with tilt and swivel capabilities, offering flexible viewing angles for an optimal viewing experience.
  • Durable construction
    Crafted from aluminum, this mounting kit ensures sturdy and reliable support for LCD displays, making it a lasting addition to any setup.
  • Easy installation
    With its wall-mountable design and included pivot wall mount, setting up your LCD display is straightforward, allowing for seamless integration into your space.
Peerless SmartMount Pivot Wall Mount SP730P mounting kit - Tilt & Swivel - for LCD display - black
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Pivot wall mount
80 g
Recommended Use
LCD display
Recommended Display Size
10"-29"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Anodised aluminium
5-year warranty
80 g
Material
Anodised aluminium
AV Furniture
Mounting kit
Mounting Components
Pivot wall mount
Design
Tilt & Swivel
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
10"-29"
Max Load Weight
11.3 kg
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
