Peerless-AV’s SmartMount® Universal Flat Wall Mount delivers an ultra-slim profile designed to hold large displays up to 350lb. Installation and maintenance are made easy with the SF680’s robust feature set. Auto-latching adaptor rails automatically secure the display without the use of a tool. The mount’s built-in kickstand holds the display safely from the wall during cable routing, while the open wall plate allows for increased electrical and cable management options. Horizontal and vertical display adjustment allow for quick fine-tuning of the mounted display.
- Peerless SmartMount Universal Flat Wall Mount SF680P mounting kit - for flat panel - black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, bracket adapter
- 116.2 cm x 5 cm x 76.8 cm
- 6.1 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 60"-95"
- VESA Mounting Interface
- 1100 x 650 mm
- Max Load Weight
- 158.8 kg
- Material
- Steel, fused epoxy
- Black
- 5-year warranty
- 116.2 cm
- 5 cm
- 76.8 cm
- 6.1 kg
- Material
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 1100 x 650 mm
- 60"-95"
- Max Load Weight
- 158.8 kg
- Sorted-For-You, scratch-resistant
- Limited warranty - 5 years
