Peerless-AV SmartMount Universal Flat Wall Mount for 60" to 98" Displays
CLEARANCE!
Clearance
Price Drop
Quicklinx: 7MV2WS00 Mfr#: SF680P
Type: Mounting kit
25 In Stock
£157.86 ex VAT
£189.43 inc VAT
Peerless-AV’s SmartMount® Universal Flat Wall Mount delivers an ultra-slim profile designed to hold large displays up to 350lb. Installation and maintenance are made easy with the SF680’s robust feature set. Auto-latching adaptor rails automatically secure the display without the use of a tool. The mount’s built-in kickstand holds the display safely from the wall during cable routing, while the open wall plate allows for increased electrical and cable management options. Horizontal and vertical display adjustment allow for quick fine-tuning of the mounted display.
  • Robust construction
    Crafted from fused epoxy and steel, the Peerless SmartMount Universal Flat Wall Mount is designed to offer durability and scratch resistance, ensuring your flat panel remains securely mounted and in pristine condition.
  • Versatile compatibility
    With a flat panel mount interface of 1100 x 650 mm and the ability to support display sizes from 60"-95", this mounting kit is versatile, making it suitable for a wide range of flat panel displays.
  • Substantial weight capacity
    Engineered to support a maximum load weight of 158.8 kg, this mounting kit can safely hold even the heaviest flat panels, providing peace of mind and a secure installation.
Peerless SmartMount Universal Flat Wall Mount SF680P mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall plate, bracket adapter
116.2 cm x 5 cm x 76.8 cm
6.1 kg
Recommended Use
Flat panel
Recommended Display Size
60"-95"
VESA Mounting Interface
1100 x 650 mm
Max Load Weight
158.8 kg
Material
Steel, fused epoxy
5-year warranty
116.2 cm
5 cm
76.8 cm
6.1 kg
Material
Steel, fused epoxy
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
1100 x 650 mm
60"-95"
Max Load Weight
158.8 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
