Peerless-AV SmartMount Universal Flat Wall Mount for 46" to 90" Displays
Quicklinx: 7MV1WS00 Mfr#: SF670P
Type: Mounting kit
18 In Stock
£121.01 ex VAT
£145.21 inc VAT
Ideally suited for XX large LCD and plasma screens, the SmartMount SF670P flat-to-wall mount allows you to mount your LCD/plasma screen quickly and easily.
  • Robust construction
    Crafted from fused epoxy and steel, the Peerless SmartMount Universal Flat Wall Mount offers a durable and reliable solution for mounting flat panels. Its scratch-resistant design ensures that both the mount and the mounted device maintain their aesthetic appeal over time.
  • Versatile compatibility
    Designed to support flat panel displays ranging from 46" to 90", this mounting kit includes a bracket adapter and wall plate, making it a versatile choice for a wide array of flat panel sizes. The flat panel mount interface of 895 x 450 mm further enhances its compatibility with various display models.
  • Substantial weight capacity
    With the ability to hold up to 113.4 kg, the Peerless SmartMount Universal Flat Wall Mount is capable of supporting even the heaviest of flat panel displays, ensuring a secure and stable mounting solution for your valuable equipment.
Peerless SmartMount Universal Flat Wall Mount SF670P mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall plate, bracket adapter
95.9 cm x 5 cm x 52.4 cm
4.7 kg
Recommended Use
Flat panel
Recommended Display Size
46"-90"
VESA Mounting Interface
895 x 450 mm
Max Load Weight
113.4 kg
Material
Steel, fused epoxy
5-year warranty
95.9 cm
5 cm
52.4 cm
4.7 kg
Material
Steel, fused epoxy
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
895 x 450 mm
46"-90"
Max Load Weight
113.4 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
