Peerless-AV SmartMount Universal Flat Wall Mount for 37" to 75" Displays
Quicklinx: 7JQ1WS00 Mfr#: SF650P
Type: Mounting kit
44 In Stock
£59.49 ex VAT
£71.38 inc VAT
Ideally suited for large LCD and Plasma screens, the SmartMount SF650P flat-to-wall mount allows you to mount your LCD/Plasma screen quickly and easily. The low profile design holds the screen only 43mm away from the wall.
  • Robust Construction
    Crafted from fused epoxy and hardened steel, this mounting kit offers a durable solution for securing your flat panel display. Its scratch-resistant design ensures that both the mount and your display remain in pristine condition, even after extensive use.
  • Versatile Compatibility
    Designed to accommodate a wide range of flat panel sizes, from 39" to 75" or 99.1 to 190.5 cm, the Peerless SmartMount Universal Flat Wall Mount ensures a perfect fit for your display. The deep bracket and wall plate components provide a stable and secure mounting solution, suitable for various installation environments.
  • Easy Installation
    The Sorted-For-You feature simplifies the installation process, ensuring that all necessary components are organized and easy to access. This user-friendly approach minimizes setup time and allows for a hassle-free installation experience.
Peerless SmartMount Universal Flat Wall Mount SF650P mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall plate, deep bracket
78.1 cm x 4.3 cm x 45.7 cm
3.5 kg
Recommended Use
Flat panel
Recommended Display Size
39"-75"
VESA Mounting Interface
Up to 742 x 405 mm
Max Load Weight
79 kg
Material
Hardened steel, fused epoxy
78.1 cm
4.3 cm
45.7 cm
3.5 kg
Material
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Up to 742 x 405 mm
39"-75"
Max Load Weight
79 kg
Sorted-For-You, scratch-resistant
Type: Mounting kit
Brand: Peerless-AV
