Ideally suited for large LCD and Plasma screens, the SmartMount SF650P flat-to-wall mount allows you to mount your LCD/Plasma screen quickly and easily. The low profile design holds the screen only 43mm away from the wall.
Robust Construction
Crafted from fused epoxy and hardened steel, this mounting kit offers a durable solution for securing your flat panel display. Its scratch-resistant design ensures that both the mount and your display remain in pristine condition, even after extensive use. -
Versatile Compatibility
Designed to accommodate a wide range of flat panel sizes, from 39" to 75" or 99.1 to 190.5 cm, the Peerless SmartMount Universal Flat Wall Mount ensures a perfect fit for your display. The deep bracket and wall plate components provide a stable and secure mounting solution, suitable for various installation environments. -
Easy Installation
The Sorted-For-You feature simplifies the installation process, ensuring that all necessary components are organized and easy to access. This user-friendly approach minimizes setup time and allows for a hassle-free installation experience.
 - Peerless SmartMount Universal Flat Wall Mount SF650P mounting kit - for flat panel - black
- Product Type
 - Mounting kit
- Mounting Components
 - Wall plate, deep bracket
 - 78.1 cm x 4.3 cm x 45.7 cm
 - 3.5 kg
- Recommended Use
 - Flat panel
- Recommended Display Size
 - 39"-75"
- VESA Mounting Interface
 - Up to 742 x 405 mm
- Max Load Weight
 - 79 kg
- Material
 - Hardened steel, fused epoxy
 - Black
 - 78.1 cm
 - 4.3 cm
 - 45.7 cm
 - 3.5 kg
- Material
 - Black
AV Furniture
 - Mounting kit
- Recommended Use
 - Flat panel
 - 39"-75"
- Max Load Weight
 - 79 kg
 - Sorted-For-You, scratch-resistant
