Peerless-AV SmartMount Universal Flat Wall Mount for 10" to 29" Displays
Quicklinx: 7MTWWS00 Mfr#: SF630P
Type: Mounting kit
12 In Stock
£19.11 ex VAT
£22.93 inc VAT
Ideally suited for small LCD screens, the SmartMount SF630P flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 25mm away from the wall.
  • Durable design
    Engineered with a scratch-resistant finish, this wall mount ensures your LCD display remains pristine and unblemished, maintaining its sleek appearance over time.
  • Versatile compatibility
    Featuring flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, this mounting kit is designed to accommodate a wide range of LCD displays, offering a flexible solution for your viewing needs.
  • Robust support
    Capable of supporting LCD displays weighing up to 36.3 kg, this wall mount provides a secure and stable platform, ensuring your screen stays firmly in place.
Peerless SmartMount Universal Flat Wall Mount SF630P mounting kit - for LCD display - black
Mounting kit
Mounting Components
Wall plate, mounting adapter
15.3 cm x 2.48 cm x 14.6 cm
0.8 kg
Recommended Use
LCD display
Recommended Display Size
10"-29"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.3 kg
5-year warranty
15.3 cm
2.48 cm
14.6 cm
0.8 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
10"-29"
Max Load Weight
36.3 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
