Peerless-AV SmartMount Universal Articulating Wall Mount For 37" to 55" Displays
Quicklinx: 79J0WS00 Mfr#: SA752PU
Type: Mounting kit
£254.66 ex VAT
£305.59 inc VAT
From any angle, this wall mount reflects remarkable form and function. Extending the flat panel display up to 27.43" (697mm) from the wall and allowing for a full 180° of side-to-side motion for perfect view positioning of displays up to 52". Fine-tuning of the installation is simple with its side-to-side display leveling and 1" (25.4mm) of vertical adjustment features that help achieve perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a desirable cable management system, centering the flat panel display on the wall when retracted and organizing and protecting the cables. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Mounts.
  • Clean application
    Built in cable management system keeps cables organized and protected.
  • Remarkable form
    Cable covers, and fastener covers complete a professional installation.
  • Post installation leveling
    ±5 degrees of roll eases mounting frustration.
Peerless Universal Full-Motion Plus Wall Mount SA752PU mounting kit - for flat panel - gloss black
Mounting kit - wall-mountable
Mounting Components
Wall mount
72.8 cm x 11.3 cm x 45.7 cm
Adjustable Depth
11.3-69.7 cm
Adjustments
Tilt
15 kg
Recommended Use
Flat panel
Recommended Display Size
37"-55"
VESA Mounting Interface
Up to 600 x 400 mm
Max Load Weight
41 kg
Material
Fused epoxy
Gloss black
5-year warranty
72.8 cm
11.3 cm
45.7 cm
Adjustable Depth
11.3-69.7 cm
15 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Up to 600 x 400 mm
Cable Management
Cable Management System (CMS)
37"-55"
Adjustments
Tilt
Max Load Weight
41 kg
Swivel base, adjustable depth, rotating, scratch-resistant, vertical screen orientation, swivel adjustment
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
