The ACC979 SmartMount SR Cart Caster accessory kit comes with 2 locking and 2 non locking 4" swivel casters for converting any SmartMount stand to a rolling cart.
Effortless mobility
Equipped with 2 casters and 2 lockable casters, this mounting component ensures easy movement and stable placement, making it ideal for dynamic environments. -
Robust support
Designed to support a maximum load weight of 102.3 kg, this floor stand mountable component offers reliable stability for a wide range of AV equipment. -
Versatile placement
With its floor stand mountable design, this product provides flexible placement options, ensuring optimal viewing angles and enhanced user interaction.
- Peerless-AV SmartMount ACC979 mounting component - black
- Product Type
- Mounting component - floor stand mountable
- Mounting Components
- 2 casters, 2 lockable casters
- Adjustments
- Yaw
- Max Load Weight
- 102.3 kg
- Black
- Black
AV Furniture
- Placing / Mounting
- Floor stand mountable
- Adjustments
- Yaw
- Max Load Weight
- 102.3 kg
- Wheel Diameter
- 10.2 cm
