Peerless-AV SmartMount Pivot Wall Mount
For 32" to 50" Displays
Peerless-AV SmartMount Pivot Wall Mount For 32" to 50" Displays
Quicklinx: 7MVJWS00 Mfr#: SP746PU
Type: Mounting kit
£143.10 ex VAT
£171.72 inc VAT
Supporting screens up to 46" the SP746PU mount provides pivoting functionality for the viewing angle adjustment when full articulation is not required. This user-friendly and easy to install mount delivers one touch side-to-side swivel and tilting functionality that is complemented by its lightweight construction and intuitive three step installation process. Adding to its pivot functionality is the mount's clean aesthetic, contributed to by its cable management system that easily organizes and routes cables, focusing all the attention on the screen.
  • Effortless adjustment
    With its tilt and swivel adjustments, the Peerless SmartMount Pivot Wall Mount allows for optimal viewing angles and positions, ensuring a comfortable and customizable viewing experience.
  • Seamless cable management
    The integrated Cable Management System (CMS) keeps cables neatly organized and out of sight, contributing to a clean and clutter-free installation.
  • Durable design
    Constructed from fused epoxy, this mounting kit is designed to resist scratches, ensuring a long-lasting, pristine appearance for any setting.
  • Versatile compatibility
    Designed to support flat panels ranging from 22" to 50" and capable of handling up to 36 kg, this mount is a versatile solution for a wide range of displays.
Peerless SmartMount Pivot Wall Mount SP746PU mounting kit - for flat panel - gloss black
Mounting kit - wall-mountable
Mounting Components
Pivot wall mount
47.6 cm 43.2 cm
Adjustable Depth
9.5-31.9 cm
Adjustments
Tilt
3.28 kg
Recommended Use
Flat panel
Recommended Display Size
22"-50"
VESA Mounting Interface
400 x 400 mm
Max Load Weight
36 kg
Material
Fused epoxy
Gloss black
5-year warranty
47.6 cm
43.2 cm
Adjustable Depth
9.5-31.9 cm
3.28 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Pivot wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
400 x 400 mm
Cable Management
22"-50"
Adjustments
Tilt
Max Load Weight
36 kg
Adjustable depth, scratch-resistant, swivel adjustment
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
