Supporting screens up to 46" the SP746PU mount provides pivoting functionality for the viewing angle adjustment when full articulation is not required. This user-friendly and easy to install mount delivers one touch side-to-side swivel and tilting functionality that is complemented by its lightweight construction and intuitive three step installation process. Adding to its pivot functionality is the mount's clean aesthetic, contributed to by its cable management system that easily organizes and routes cables, focusing all the attention on the screen.
Effortless adjustment
With its tilt and swivel adjustments, the Peerless SmartMount Pivot Wall Mount allows for optimal viewing angles and positions, ensuring a comfortable and customizable viewing experience. -
Seamless cable management
The integrated Cable Management System (CMS) keeps cables neatly organized and out of sight, contributing to a clean and clutter-free installation. -
Durable design
Constructed from fused epoxy, this mounting kit is designed to resist scratches, ensuring a long-lasting, pristine appearance for any setting. -
Versatile compatibility
Designed to support flat panels ranging from 22" to 50" and capable of handling up to 36 kg, this mount is a versatile solution for a wide range of displays.
- Peerless SmartMount Pivot Wall Mount SP746PU mounting kit - for flat panel - gloss black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Pivot wall mount
- 47.6 cm 43.2 cm
- Adjustable Depth
- 9.5-31.9 cm
- Adjustments
- Tilt
- 3.28 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 22"-50"
- VESA Mounting Interface
- 400 x 400 mm
- Max Load Weight
- 36 kg
- Material
- Fused epoxy
- Gloss black
- 5-year warranty
- 47.6 cm
- 43.2 cm
- Adjustable Depth
- 9.5-31.9 cm
- 3.28 kg
- Material
- Fused epoxy
- Gloss black
AV Furniture
- Mounting kit
- Pivot wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 400 x 400 mm
- Cable Management
- Cable Management System (CMS)
- 22"-50"
- Adjustments
- Tilt
- Max Load Weight
- 36 kg
- Adjustable depth, scratch-resistant, swivel adjustment
- Limited warranty - 5 years
