Peerless-AV SmartMount Dedicated Tilt Wall Mount
Quicklinx: 9YZFWS00 Mfr#: ST16D
£125.84 ex VAT
£151.00 inc VAT
Tilting wall mount for use with PLP-UN-1 universal bracket allowing screen to be installed in portrait or landscape orientation.
Peerless SmartMount Dedicated Tilt Wall Mount ST16D mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Fasteners, bracket, adapter plate, tilt wall plate
48.9 cm x 7.9 cm x 26.7 cm
Adjustments
Tilt
4 kg
Recommended Use
Flat panel
Recommended Display Size
22"
Max Load Weight
90.7 kg
5-year warranty
48.9 cm
7.9 cm
26.7 cm
4 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
22"
Adjustments
Tilt
Max Load Weight
90.7 kg
Scratch-resistant
Limited warranty - 5 years
Brand: Peerless-AV
