From any angle, this wall mount reflects remarkable form and function. Extending the flat panel display up to 27.55" (700mm) from the wall and allowing for viewing in any part of the room. Fine-tuning of the installation is simple with its side-to-side display leveling and 1" (25mm) of vertical adjustment features that help achieve installation perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a desirable cable management system, centering the TV on the wall when retracted and organizing and protecting the cables at all times. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Mounts.
                Versatile viewingWith adjustments for tilt and a full-motion plus wall mount, this mounting kit offers optimal viewing angles for any setup, ensuring a comfortable and customizable viewing experience.
                Robust supportDesigned to hold large LCD displays ranging from 46"-90" or 116.8-228.6 cm and capable of supporting up to 68.04 kg, this mount provides a secure and stable platform for your premium display units.
                Seamless integrationThe articulating arm and wall plate components ensure a smooth installation process, fitting flat panel mount interfaces up to 800 x 400 mm, making it a versatile choice for a wide range of LCD displays.
- Peerless Universal Full-Motion Plus Wall Mount SA771PU mounting kit - for LCD display
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, articulating arm
- 112.9 cm 66.1 cm
- Adjustments
- Tilt
- Recommended Use
- LCD display
- Recommended Display Size
- 46"-90"
- VESA Mounting Interface
- Up to 800 x 400 mm
- Max Load Weight
- 68.04 kg
- 112.9 cm
- 66.1 cm
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- 46"-90"
- Adjustments
- Tilt
- Max Load Weight
- 68.04 kg
