Peerless-AV SmartMount Articulating Wall Mount for 39"-75" Displays
Quicklinx: 7MVLWS00 Mfr#: SA761PU
Type: Mounting kit
£363.00 ex VAT
£435.60 inc VAT
Ideally suited for extra large LCD and plasma screens, the SmartMount SA761PU articulating wall mount gives you the widest range of screen adjustment to obtain the best possible viewing angle. Tilt back or forward, pan left or right, even extend your flat panel screen away from the wall - the SA761PU has it all.
  • Clean application
    Built in cable management system keeps cables organized and protected.
  • Clean appearance
    Open wall plate design for installation flexibility.
  • Post installation leveling
    ±5 degrees of roll eases mounting frustration.
Peerless Universal Full-Motion Plus Wall Mount SA761PU mounting kit - for flat panel - gloss black
Mounting kit - wall-mountable
Mounting Components
Wall mount
72.8 cm x 11.3 cm x 45.7 cm
Adjustable Depth
11.3-70 cm
Adjustments
Tilt
18 kg
Recommended Use
Flat panel
Recommended Display Size
39"-75"
VESA Mounting Interface
600 x 400 mm
Max Load Weight
56.7 kg
Material
Fused epoxy
Gloss black
5-year warranty
72.8 cm
11.3 cm
45.7 cm
Adjustable Depth
11.3-70 cm
18 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
600 x 400 mm
Cable Management
Cable Management System (CMS)
39"-75"
Adjustments
Tilt
Max Load Weight
56.7 kg
Horizontal or vertical screen orientation, swivel base, adjustable depth, scratch-resistant, swivel adjustment
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
