Peerless-AV SmartMount Articulating Wall Mount For 10"-29" Displays
Quicklinx: 7MVKWS00 Mfr#: SA730P
Type: Mounting kit
£82.21 ex VAT
£98.65 inc VAT
From any angle, this wall arm mount reflects remarkable form and function. Extending the display up to 16" from the wall and allowing for a full 180° of side-to-side motion for viewing in any part of the room. Fine-tuning of the installation is simple with its side-to-side display leveling features that help achieve installation perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a cable management system, centering the TV on the wall when retracted and organizing and protecting the cables at all times. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Arm Mounts.
  • Flexible viewing
    The Peerless Full-Motion Plus Wall Mount offers tilt and swivel capabilities, allowing for optimal viewing angles and enhanced user comfort. Its articulating arm ensures you can adjust your LCD TV to the perfect position, whether for gaming, presentations, or cozy movie nights.
  • Universal compatibility
    Designed to support LCD TVs ranging from 10" to 29", this mounting kit is versatile for use in various settings, from home entertainment systems to professional displays. It includes flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, ensuring a fit for a wide range of television sizes.
Peerless Full-Motion Plus Wall Mount SA730P mounting kit - Tilt & Swivel - for LCD TV - black
Mounting kit (Tilt & Swivel)
Mounting Components
Articulating arm
Recommended Use
LCD TV
Recommended Display Size
10"-29"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
AV Furniture
Mounting kit
Mounting Components
Articulating arm
Design
Tilt & Swivel
Recommended Use
LCD TV
10"-29"
Type: Mounting kit
Brand: Peerless-AV
