From any angle, this Full-Motion Plus Wall Mount reflects remarkable form and function. This noticeably smaller and lighter weight universal, two-link Full-Motion Plus Wall Mount will accommodate a wide range of displays, delivering ultimate performance and maximum support with a minimal footprint. This Full-Motion Plus Wall Mount's design features a fold-flat-and-center design that centers the display on the wall plate when the mount is in its closed position. It provides a clean aesthetic with its cable management system that easily hides, organizes and routes cables, focusing all the attention on the display. With an exceptional extension up to 20.18" (513mm) from the wall and a full 180° of side-to-side motion, this mount provides virtually unlimited viewing possibilities. Installation is made simple with post installation fine-tuning that allows for display alignment adjustments, ensuring the display is level even if the mounting surface is not perfect. Designed and built in the USA.
- Peerless Full-Motion Plus Wall Mount SA746PU - mounting kit
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, articulating arm
- 47.6 cm 43.2 cm
- Adjustable Depth
- 11-53.1 cm
- Adjustments
- Tilt
- 4 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 22"-50"
- VESA Mounting Interface
- 400 x 400 mm
- Max Load Weight
- 36 kg
- Material
- Fused epoxy
- Gloss black
- 5-year warranty
- 47.6 cm
- 43.2 cm
- Adjustable Depth
- 11-53.1 cm
- 4 kg
- Material
- Fused epoxy
- Gloss black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 400 x 400 mm
- Cable Management
- Cable Management System (CMS)
- 22"-50"
- Adjustments
- Tilt
- Max Load Weight
- 36 kg
- Adjustable depth, scratch-resistant
- Limited warranty - 5 years
