Peerless-AV SmartMount Articulating Wall Arm For 32"-50" Displays
Quicklinx: 7MSBWS00 Mfr#: SA746PU
Type: Mounting kit
Hurry, only 3 left in stock!
£172.53 ex VAT
£207.03 inc VAT
From any angle, this Full-Motion Plus Wall Mount reflects remarkable form and function. This noticeably smaller and lighter weight universal, two-link Full-Motion Plus Wall Mount will accommodate a wide range of displays, delivering ultimate performance and maximum support with a minimal footprint. This Full-Motion Plus Wall Mount's design features a fold-flat-and-center design that centers the display on the wall plate when the mount is in its closed position. It provides a clean aesthetic with its cable management system that easily hides, organizes and routes cables, focusing all the attention on the display. With an exceptional extension up to 20.18" (513mm) from the wall and a full 180° of side-to-side motion, this mount provides virtually unlimited viewing possibilities. Installation is made simple with post installation fine-tuning that allows for display alignment adjustments, ensuring the display is level even if the mounting surface is not perfect. Designed and built in the USA.
  • Effortless adjustment
    The Peerless Full-Motion Plus Wall Mount offers seamless tilt adjustments, allowing for the perfect viewing angle in any room setup.
  • Sophisticated cable management
    Equipped with a Cable Management System (CMS), this mounting kit ensures that cables are neatly organized and hidden from view, maintaining a clean and clutter-free appearance.
  • Durable design
    Constructed from fused epoxy, the mount is not only scratch-resistant but also designed to last, providing a reliable solution for mounting flat panels.
  • Versatile compatibility
    Designed to support flat panel displays ranging from 22" to 50" and capable of handling up to 36 kg, this mount is versatile enough to accommodate a wide range of TV sizes and weights.
Peerless Full-Motion Plus Wall Mount SA746PU mounting kit - for flat panel - gloss black
Mounting kit
Mounting Components
Wall plate, articulating arm
47.6 cm 43.2 cm
Adjustable Depth
11-53.1 cm
Adjustments
Tilt
4 kg
Recommended Use
Flat panel
Recommended Display Size
22"-50"
VESA Mounting Interface
400 x 400 mm
Max Load Weight
36 kg
Material
Fused epoxy
Gloss black
5-year warranty
47.6 cm
43.2 cm
Adjustable Depth
11-53.1 cm
4 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
400 x 400 mm
Cable Management
22"-50"
Adjustments
Tilt
Max Load Weight
36 kg
Adjustable depth, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
