Peerless-AV Slimline Ultra-Flat to Wall Mount in Black 68kg (15
Quicklinx: 7YPYWS00 Mfr#: SUF640P
Type: Mounting kit
Hurry, only 1 left in stock!
£81.65 ex VAT
£97.98 inc VAT
Ultra Slim is the world's thinnest flat to wall mounting solution at less that 0.84cm - yes that's only 8.4mm! - making it almost invisible once installed. Designed for the next generation of super slim LCD panels this product is a step ahead of anything else available in the market. Own the most discrete wall mount ever developed with the Ultra Slim range from Peerless.
  • Robust construction
    Crafted from cold-rolled steel, this mounting kit offers a durable solution for securing your flat panel display. Its scratch-resistant finish ensures the mount maintains its sleek appearance, even under frequent use.
  • Versatile compatibility
    Designed to support flat panel displays ranging from 37" to 50", or 94 to 127 cm, the Peerless Slimline Universal Ultra-Thin Flat Wall Mount accommodates a wide range of sizes, making it an ideal choice for various home or office settings.
  • Easy installation
    The inclusion of a bracket adapter and wall plate simplifies the mounting process, allowing for a straightforward setup. This design ensures your display is securely mounted with minimal effort.
Peerless Slimline Universal Ultra-Thin Flat Wall Mount SUF640P mounting kit - for flat panel - high-gloss black
Mounting kit
Mounting Components
Wall plate, bracket adapter
52.6 cm x 1 cm x 40.9 cm
1.52 kg
Recommended Use
Flat panel
Recommended Display Size
37"-50"
Max Mounting Pattern Size
450 x 402 mm
Max Load Weight
68 kg
Material
Cold-rolled steel
High-gloss black
5-year warranty
52.6 cm
1 cm
40.9 cm
1.52 kg
Material
Cold-rolled steel
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
450 x 402 mm
37"-50"
Max Load Weight
68 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
