- Peerless ACC324 shelf - for audio/video components - black
- Product Type
- Shelf
- 73.7 cm x 68.6 cm x 3.8 cm
- Recommended Use
- Audio/video components
- Max Load Weight
- 11.3 kg
- Black
- 5-year warranty
- Designed For
- Peerless CM50, CM60, CM850; Flat Panel Corner Mount CM50, CM850
- 73.7 cm
- 68.6 cm
- 3.8 cm
- Black
AV Furniture
- Shelf
- Recommended Use
- Max Load Weight
- 11.3 kg
- Limited warranty - 5 years
- Designed For
- Peerless CM50, CM60, CM850 , Peerless Flat Panel Corner Mount CM50, CM850
