Peerless-AV Shelf for Corner Mount
Quicklinx: 9Z0CWS00 Mfr#: ACC324
£66.93 ex VAT
£80.31 inc VAT
This triangular shape shelf provides ample space for A/V equipment.
Peerless ACC324 shelf - for audio/video components - black
Shelf
73.7 cm x 68.6 cm x 3.8 cm
Recommended Use
Audio/video components
Max Load Weight
11.3 kg
5-year warranty
Peerless CM50, CM60, CM850; Flat Panel Corner Mount CM50, CM850
73.7 cm
68.6 cm
3.8 cm
AV Furniture
Shelf
Recommended Use
Max Load Weight
11.3 kg
Limited warranty - 5 years
Peerless CM50, CM60, CM850 , Peerless Flat Panel Corner Mount CM50, CM850
Brand: Peerless-AV
