Peerless-AV's SmartMount Universal Portrait Flat wall mount delivers an ultra-slim profile designed to hold large displays. Installation and maintenance are made easy with the SFP680's robust feature set. Auto-latching adaptor rails automatically secure the display without the use of a tool. The mount's built-in kickstand holds the display safely from the wall during cable routing, while the open wall plate allows for increased electrical and cable management options. Horizontal and vertical display adjustment allow for quick fine-tuning of the mounted display.
- Peerless-AV SmartMount Universal Portrait Flat SFP680 bracket - Ultra-Slim - for flat panel - black
- Product Type
- Bracket (Ultra-Slim) - wall-mountable - lockable
- 55.9 cm x 4.3 cm x 69.8 cm
- Adjustments
- Horizontal
- 5.4 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 46"-90"
- VESA Mounting Interface
- Up to 650 x 400 mm
- Max Load Weight
- 158.76 kg
- Black
- 55.9 cm
- 4.3 cm
- 69.8 cm
- 5.4 kg
- Black
AV Furniture
- Bracket
- Design
- Ultra-Slim
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- Cable Management
- Cable Management System (CMS)
- Lockable
- 46"-90"
- Adjustments
- Horizontal
- Max Load Weight
- 158.76 kg
- Finish
- Powder coated
Peerless-AV SFP680 Flat Wall Mount Port 46-90 158kg
