Peerless-AV SFP680 Flat Wall Mount Port 46-90 158kg
Quicklinx: GRH7WS00 Mfr#: SFP680
11 In Stock
£152.66 ex VAT
£183.19 inc VAT
Peerless-AV's SmartMount Universal Portrait Flat wall mount delivers an ultra-slim profile designed to hold large displays. Installation and maintenance are made easy with the SFP680's robust feature set. Auto-latching adaptor rails automatically secure the display without the use of a tool. The mount's built-in kickstand holds the display safely from the wall during cable routing, while the open wall plate allows for increased electrical and cable management options. Horizontal and vertical display adjustment allow for quick fine-tuning of the mounted display.
Peerless-AV SmartMount Universal Portrait Flat SFP680 bracket - Ultra-Slim - for flat panel - black
Bracket (Ultra-Slim) - wall-mountable - lockable
55.9 cm x 4.3 cm x 69.8 cm
Adjustments
Horizontal
5.4 kg
Recommended Use
Flat panel
Recommended Display Size
46"-90"
VESA Mounting Interface
Up to 650 x 400 mm
Max Load Weight
158.76 kg
55.9 cm
4.3 cm
69.8 cm
5.4 kg
AV Furniture
Bracket
Design
Ultra-Slim
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Up to 650 x 400 mm
Cable Management
Cable Management System (CMS)
Lockable
46"-90"
Adjustments
Horizontal
Max Load Weight
158.76 kg
Finish
Powder coated
Brand: Peerless-AV
