Large Flat Panel adapter plates (PLP models) are either universally compatible with most large flat panels, or uniquely compatible with one screen make or model. Peerless adapter plates for flat panels allow users to choose between Peerless' wide array of applications and accessories to mount a flat panel virtually anywhere. Most models feature security fasteners for theft resistance.
- Peerless Universal Adapter Plate PLP UNL mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Bracket, adapter plate
- 78.1 cm 43.3 cm
- 5.2 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-60"
- Max Load Weight
- 90.7 kg
- Material
- Cold-rolled steel
- Black
- 78.1 cm
- 43.3 cm
- 5.2 kg
- Material
- Cold-rolled steel
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 32"-60"
- Max Load Weight
- 90.7 kg
