Peerless-AV Security Pull-Out Swivel Mount for 32-58" Flat Panel Displays
Quicklinx: 9Z00WS00 Mfr#: SP850-UNL
13 In Stock
£351.85 ex VAT
£422.22 inc VAT
The SmartMount Pull-Out Swivel Wall Mount combines the best features of a wall mount and a pivot arm. In the closed position, the SP850-UNL acts as a flat or tilting wall mount. At only 3.4" away from the wall, its unique wall plate and built-in cable management neatly hide all components and cords. Extended, the SP850's sturdy arm construction smoothly glides the screen out 11.9" from the wall and allows the screen to pivot up to 45 degrees. This feature not only enables the screen to be positioned for an optimal viewing angle, but it also provides easy access to the back of the screen for maintenance. The SP850-UNL is also ideal in applications where the screen needs to be recessed into a cubby hole, custom frame or aligned into a video wall. Mounts to 16" wood studs, concrete or cinder block.
  • Versatile placement
    Designed for versatility, the Peerless SmartMount Pull-out Swivel Mount allows for easy tilt and swivel adjustments, ensuring an optimal viewing angle for every use case. Its wall-mountable design supports a wide range of flat panel sizes from 32"-80", making it suitable for various room sizes and layouts.
  • Robust construction
    Crafted from high-quality steel, this mounting kit is built to last. It can securely hold flat panels weighing up to 68.2 kg, thanks to its durable adapter plate and swivel wall mount components. The construction ensures stability and security for your flat panel display.
  • Easy installation
    The Peerless SmartMount Pull-out Swivel Mount comes with all necessary mounting components, including an adapter plate and a swivel wall mount, facilitating a hassle-free installation process. Its design ensures compatibility with a wide range of display sizes, offering a straightforward setup for users.
Peerless SmartMount Pull-out Swivel Mount SP850-UNL mounting kit - Tilt & Swivel - for flat panel - black
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Adapter plate, swivel wall mount
78.1 cm 45.7 cm
9.1 kg
Recommended Use
Flat panel
Recommended Display Size
32"-80"
Max Mounting Pattern Size
729 x 433 mm
Max Load Weight
68.2 kg
Material
Steel
5-year warranty
78.1 cm
45.7 cm
9.1 kg
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
729 x 433 mm
32"-80"
Max Load Weight
68.2 kg
Limited warranty - 5 years
Brand: Peerless-AV
