- Peerless Universal I-Shaped Adaptor PLP-UNM mounting component - for flat panel - black
- Product Type
- Mounting component
- Mounting Components
- Mounting adapter
- 41.9 cm x 1.8 cm x 42.5 cm
- 1.95 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 22"-50"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 100 mm, 400 x 200 mm, 400 x 400 mm
- Max Load Weight
- 68.2 kg
- Material
- Cold-rolled steel
- Black
- 5-year warranty
- 41.9 cm
- 1.8 cm
- 42.5 cm
- 1.95 kg
- Material
- Cold-rolled steel
- Black
AV Furniture
- Mounting adapter
- Recommended Use
- Flat panel
- 22"-50"
- Max Load Weight
- 68.2 kg
- Finish
- Powder coated
- Limited warranty - 5 years
