Peerless-AV's Mobile Cart with Rotational Interface has been designed to support the features and functionality of the 55" and 65" Samsung Flip 2 displays. Mobility, appealing design, display height adjustment and a pre-assembled base ensure quick assembly, while providing a rigid, but attractive structure to match the display's aesthetics. The 4" casters make it easy to move from room-to-room and optional bumper accessories ensure nothing is damaged along the way. The mount's rotational interface allows the user to easily rotate the display 90° from landscape to portrait, and holds the display at a 0° or -4.5° to further promote ergonomics with a more natural angled writing surface. The unique cable management system allows cables to be routed through the interface, which keeps the cabling safe and abrasion free when rotating the display. With a robust feature set featured on safety and durability, the Mobile Cart with Rotational Interface is ideal for collaboration spaces in corporate or education settings.
Versatile adjustments
With height, rotation, and tilt adjustments, the Peerless-AV SR560-FLIP2 cart offers flexibility for interactive displays. Whether in landscape or portrait orientation, it ensures optimal viewing angles for any presentation or collaborative work. -
Robust design
Crafted from durable aluminum with a powder-coated finish, this cart is designed to support interactive flat panels and LCD displays ranging from 55" to 65". Its sturdy construction can handle up to 41 kg, making it a reliable choice for educational, corporate, or retail environments. -
Effortless mobility
Equipped with four wheels, including two locking swivel casters, the SR560-FLIP2 ensures easy maneuverability across various surfaces. The 10.2 cm wheel diameter allows for smooth transitions, while integrated cable management keeps connections neat during movement.
- Peerless-AV SR560-FLIP2 cart - for interactive flat panel / LCD display - gloss white
- Product Type
- Cart
- 88.9 cm x 73.7 cm x 172 cm
- Tilt
- 0° / -4.5°
- Rotation
- 90°
- Adjustments
- Height, tilt, rotation
- 36.3 kg
- Recommended Use
- Interactive flat panel / LCD display
- Recommended Display Size
- 55", 65"
- VESA Mounting Interface
- 400 x 400 mm
- Max Load Weight
- 41 kg
- Material
- Aluminium
- Gloss white
- Wheels Qty
- 4
- Package Content
- Mounting hardware, column, base, universal display adapter, 2 swivel casters, 2 locking swivel casters, 4 plastic base pads
- Designed For
- Samsung Flip WM55H; Flip 2 WM55R, WM65R
- 88.9 cm
- 73.7 cm
- 172 cm
- 36.3 kg
- Material
- Aluminium
- Gloss white
- Package Content
AV Furniture
- Cart
- Recommended Use
- 400 x 400 mm
- Cable Management
- Integrated cable management
- 55", 65"
- Tilt
- 0° / -4.5°
- Rotation
- 90°
- Adjustments
- Max Load Weight
- 41 kg
- Wheels Qty
- 4
- Wheel Diameter
- 10.2 cm
- Brakes Qty
- 2
- Finish
- Powder coated
- Details
- Portrait orientation, landscape orientation
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 121.9 cm x 17.8 cm x 96.5 cm / 40.1 kg
- Designed For
- Samsung Flip WM55H , Samsung Flip 2 WM55R, WM65R
