Peerless-AV Rotating Cart Samsung Flip
Quicklinx: GRH4WS00 Mfr#: SR560-FLIP2
Hurry, only 2 left in stock!
£832.76 ex VAT
£999.31 inc VAT
Peerless-AV's Mobile Cart with Rotational Interface has been designed to support the features and functionality of the 55" and 65" Samsung Flip 2 displays. Mobility, appealing design, display height adjustment and a pre-assembled base ensure quick assembly, while providing a rigid, but attractive structure to match the display's aesthetics. The 4" casters make it easy to move from room-to-room and optional bumper accessories ensure nothing is damaged along the way. The mount's rotational interface allows the user to easily rotate the display 90° from landscape to portrait, and holds the display at a 0° or -4.5° to further promote ergonomics with a more natural angled writing surface. The unique cable management system allows cables to be routed through the interface, which keeps the cabling safe and abrasion free when rotating the display. With a robust feature set featured on safety and durability, the Mobile Cart with Rotational Interface is ideal for collaboration spaces in corporate or education settings.
  • Versatile adjustments
    With height, rotation, and tilt adjustments, the Peerless-AV SR560-FLIP2 cart offers flexibility for interactive displays. Whether in landscape or portrait orientation, it ensures optimal viewing angles for any presentation or collaborative work.
  • Robust design
    Crafted from durable aluminum with a powder-coated finish, this cart is designed to support interactive flat panels and LCD displays ranging from 55" to 65". Its sturdy construction can handle up to 41 kg, making it a reliable choice for educational, corporate, or retail environments.
  • Effortless mobility
    Equipped with four wheels, including two locking swivel casters, the SR560-FLIP2 ensures easy maneuverability across various surfaces. The 10.2 cm wheel diameter allows for smooth transitions, while integrated cable management keeps connections neat during movement.
Peerless-AV SR560-FLIP2 cart - for interactive flat panel / LCD display - gloss white
Cart
88.9 cm x 73.7 cm x 172 cm
Tilt
0° / -4.5°
Rotation
90°
Adjustments
Height, tilt, rotation
36.3 kg
Recommended Use
Interactive flat panel / LCD display
Recommended Display Size
55", 65"
VESA Mounting Interface
400 x 400 mm
Max Load Weight
41 kg
Material
Aluminium
Gloss white
Wheels Qty
4
Package Content
Mounting hardware, column, base, universal display adapter, 2 swivel casters, 2 locking swivel casters, 4 plastic base pads
Samsung Flip WM55H; Flip 2 WM55R, WM65R
88.9 cm
73.7 cm
172 cm
36.3 kg
Material
Aluminium
Gloss white
Package Content
AV Furniture
Cart
Recommended Use
400 x 400 mm
Cable Management
Integrated cable management
55", 65"
Tilt
0° / -4.5°
Rotation
90°
Adjustments
Max Load Weight
41 kg
Wheels Qty
4
Wheel Diameter
10.2 cm
Brakes Qty
2
Finish
Powder coated
Details
Portrait orientation, landscape orientation
Dimensions & Weight Details
121.9 cm x 17.8 cm x 96.5 cm / 40.1 kg
Samsung Flip WM55H , Samsung Flip 2 WM55R, WM65R
Brand: Peerless-AV
Price Range Ex VAT: £750 - £1000
