Peerless-AV RMI3-FLIP2 Rotating Wall Mount Samsung Flip
Quicklinx: GRH8WS00 Mfr#: RMI3-FLIP2
£286.10 ex VAT
£343.32 inc VAT
Peerless-AV’s Rotational Wall Mount has been designed to support the features and functionality of the 55" and 65" Samsung Flip 2 displays. The mount’s rotational interface allows the user to easily rotate the display 90° from landscape to portrait, and holds the display at 0° or -4.5° to further promote ergonomics with a more natural angled writing surface. The unique cable management system allows cables to be routed through the interface, which keeps the cabling safe and abrasion free when rotating the display. With a robust feature set featured on safety and durability, the Rotational Wall Mount is ideal for collaboration spaces in corporate or education settings.
Peerless Rotational Mount Interface RMI3-FLIP2 mounting kit - for LCD display - gloss white
Mounting kit - wall-mountable
54.9 cm x 8.2 cm x 58.9 cm
Tilt
-4.5°
Rotation
90°
Adjustments
Tilt, rotation
13.2 kg
Recommended Use
LCD display
Recommended Display Size
55"-65"
VESA Mounting Interface
400 x 400 mm
Max Load Weight
41 kg
Gloss white
Package Content
Mounting hardware
Samsung Flip WM55H; Flip 2 WM55R, WM65R; Flip Pro WM55B, WM65B
54.9 cm
8.2 cm
58.9 cm
13.2 kg
Gloss white
Package Content
Mounting hardware
AV Furniture
Mounting kit
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
400 x 400 mm
Cable Management
Integrated cable management
55"-65"
Tilt
-4.5°
Rotation
90°
Adjustments
Tilt, rotation
Max Load Weight
41 kg
Finish
Powder coated
Details
Portrait orientation, landscape orientation
Dimensions & Weight Details
92.1 cm x 11.4 cm x 61.6 cm / 14.8 kg
Samsung Flip WM55H , Samsung Flip 2 WM55R, WM65R , Samsung Flip Pro WM55B, WM65B
Brand: Peerless-AV
