Peerless-AV Pull-Out Swivel Mount Vesa 100/200x100
Quicklinx: 9YZZWS00 Mfr#: SP850
£259.25 ex VAT
£311.10 inc VAT
The SP850 Pull-out Swivel mount is designed to work with virtually any 26" to 58" Plasma or LCD flat panel display. Compatible with VESA 100 and 200 hole patterns through the integrated adapter plate, the 2" ultra-thin design keeps the screen close to the wall and the mount out of view. With a boxed in wall plate that eliminates the view of the mount hardware from a side view, the SP850 is the perfect installation product for residential, public and digital signage, POS stations and office applications. Featuring up to +/- 45° of swivel depending on the screen size and up to 10" of pull out, the SP850 provides a user with many viewing angles. Additional compatibility with Peerless' PLP or LC adapter plates makes the mount a versatile product. Installation and screen mounting are enhanced with the LockKey installation brace. Designed to mount on 16" wood studs, the wall plate accommodates up to 4" of horizontal shift.
Peerless SmartMount Pull-out Swivel Mount SP850 mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Adapter plate, swivel wall mount
53.3 cm x 5.5 cm x 24.8 cm
8 kg
Recommended Use
Flat panel
Recommended Display Size
26" - 58"
VESA Mounting Interface
100 x 100 mm, 100 x 200 mm
Max Load Weight
68 kg
53.3 cm
5.5 cm
24.8 cm
8 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
26" - 58"
Max Load Weight
68 kg
Security screws
Brand: Peerless-AV
