The HPF650 combines the best features of our FPS-1000 in one contemporary lightweight design, making it essential for on-wall or recessed/in-furniture application. With 30O of built in swivel, the HPF650 ensures your guests will always be able to find the perfect desired viewing angle. This mount is VESA® compliant, and accommodates virtually any flat panel display up to 60lb. Equipped with functionality, maximum aesthetics, versatile installation and endless display compatibility options, the HPF650 is the ideal solution for any hospitality or residential application.
- Peerless SmartMount HPF650 mounting kit - Tilt & Swivel - for LCD display - black
- Product Type
- Mounting kit (Tilt & Swivel) - wall-mountable
- Mounting Components
- Articulating arm, wall mount
- 44.9 cm 46.6 cm
- Adjustable Depth
- 3.7-25.2 cm
- Recommended Use
- LCD display
- Recommended Display Size
- 26"-47"
- VESA Mounting Interface
- 100 x 100 mm, 400 x 400 mm
- Max Load Weight
- 27 kg
- Black
- 44.9 cm
- 46.6 cm
- Adjustable Depth
- 3.7-25.2 cm
- Black
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- 26"-47"
- Max Load Weight
- 27 kg
