Peerless-AV PT632 Universal Tilt Wall Mount for 22" - 40" LCD Screens
Quicklinx: 7HCKWS00 Mfr#: PT632
Type: Mounting kit
40 In Stock
£27.38 ex VAT
£32.85 inc VAT
Ideally suited for medium (22-40") LCD screens, the Paramount PT632 tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
Peerless PARAMOUNT Tilting Wall Mount PT632 mounting kit - for LCD TV - gloss black
Mounting kit
Mounting Components
Wall plate, mounting adapter, mounting plate
22.2 cm 22.2 cm
Adjustable Depth
5.1-9.6 cm
Tilt
-5° to 15°
0.8 kg
Recommended Use
LCD TV
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
Material
Steel
Gloss black
22.2 cm
22.2 cm
Adjustable Depth
5.1-9.6 cm
0.8 kg
Material
Steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD TV
22"-40"
Tilt
-5° to 15°
Max Load Weight
36 kg
Scratch-resistant, Hook-and-Hang
Type: Mounting kit
Brand: Peerless-AV
