Peerless-AV PRGS Projector Mount for Projectors up to 22kg
Quicklinx: 9YXKWS00 Mfr#: PRGS-UNV
Hurry, only 2 left in stock!
£110.03 ex VAT
£132.03 inc VAT
The PRGS series projector mount is simplifying the way image alignment is done. The precision gear design allows exact tilt and roll image positioning by either simply turning two adjustment knobs with a Phillips screw driver, or using the tool-less option by extending the knobs to adjust by hand. Just set the precision gear to the desired position to secure it in place - it will hold its position better than the competition, even during projector maintenance. With Peerless-AV's PRGS series projector mount, just set it and forget it. No more adjustment screws. No more micro adjustments. No more hassles.
  • Effortless adjustability
    Equipped with both tilt and yaw adjustments, the PRGS-UNV mounting kit allows for precise positioning of your projector, ensuring optimal viewing angles for any presentation or home cinema setup.
  • Seamless cable management
    The integrated cable management system keeps cables neatly organized and out of sight, maintaining a clean and professional appearance for your setup.
  • Versatile mounting options
    Designed for ceiling mounting, this universal mount is compatible with a wide range of projectors, offering a secure and stable platform for your device.
Peerless PRGS-UNV mounting kit - for projector - black powder coat
Mounting kit - ceiling mountable
Mounting Components
Universal mount
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
Adjustments
Yaw, tilt
700 g
Recommended Use
Projector
Max Load Weight
22 kg
Black powder coat
5-year warranty
Adjustable Width
12.2- 44.8 cm
Adjustable Depth
12.2- 44.8 cm
Adjustable Height
9.2 -11.8 cm
700 g
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Universal mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
Adjustments
Yaw, tilt
Max Load Weight
22 kg
Swivel adjustment
Limited warranty - 5 years
Brand: Peerless-AV
