Product
Peerless-AV Portable Video Wall Cart 2x2 for 46-60" Displays
Quicklinx: 9Z0TWS00 Mfr#: DS-C560-2x2
£1,869.80 ex VAT
£2,243.76 inc VAT
Peerless-AV takes video wall carts to a new level of innovation. Designed for modularity, this 2 x 2 video wall cart configuration allows the user to create a flawless video wall with screen ranges from 46" to 60" displays. This Modular Video Wall Cart offers an 8-point micro-adjustment to create a seamless alignment without the need of tools. With a five-inch lockable caster, the cart becomes secure for safe and easy movement over various flooring surfaces. Designed for a quick set-up and tear down, the cart features a quick-connect latch for adapters, allowing automatic engagement with mounting rails. Media storage and cable management create a sleek appearance for any application setting. With an overall weight and shipping cost reduction, this Portable Video Wall Cart makes this the ultimate video wall cart solution.
Peerless-AV Portable Video Wall DS-C560-2X2 - cart
Cart
Recommended Use
4 LCD / plasma panels
Recommended Display Size
46"-60"
Flat Panel Mount Interface
200 x 200 mm, up to 600 x 400 mm
Max Load Weight
227 kg
Material
Aluminium
Black powder coat
Wheels Qty
4
Material
Aluminium
Black powder coat
AV Furniture
Cart
Recommended Use
Shelf Qty
1
Cable Management
Integrated cable management
46"-60"
Max Load Weight
227 kg
Wheels Qty
4
Wheel Diameter
12.7 cm
Eight-way micro adjustment
Brand: Peerless-AV
Price Range Ex VAT: 1500+
