Peerless-AV Portable Video Wall Cart 2x2 for 46-60" Displays
Quicklinx: 9Z0TWS00 Mfr#: DS-C560-2x2
£2,424.31 ex VAT
£2,909.17 inc VAT
Peerless-AV takes video wall carts to a new level of innovation. Designed for modularity, this 2 x 2 video wall cart configuration allows the user to create a flawless video wall with screen ranges from 46" to 60" displays. This Modular Video Wall Cart offers an 8-point micro-adjustment to create a seamless alignment without the need of tools. With a five-inch lockable caster, the cart becomes secure for safe and easy movement over various flooring surfaces. Designed for a quick set-up and tear down, the cart features a quick-connect latch for adapters, allowing automatic engagement with mounting rails. Media storage and cable management create a sleek appearance for any application setting. With an overall weight and shipping cost reduction, this Portable Video Wall Cart makes this the ultimate video wall cart solution.
  • Effortless mobility
    Equipped with four high-quality wheels measuring 12.7 cm in diameter, this portable video wall cart allows for smooth and easy movement across various surfaces, ensuring your display can be relocated with minimal effort.
  • Robust support
    Designed to hold up to 227 kg, this cart can securely accommodate four flat panels ranging from 46" to 60", making it a versatile choice for different display sizes and setups.
  • Advanced adjustability
    Featuring eight-way micro adjustment capabilities, this video wall cart allows for precise alignment of each panel, ensuring a seamless and visually appealing display setup.
  • Integrated cable management
    With its integrated cable management system, the cart keeps cables neatly organized and out of sight, promoting a clean and professional appearance for your video wall.
Peerless-AV Portable Video Wall DS-C560-2X2 cart - for 4 flat panels - black powder coat
Cart
Recommended Use
4 flat panels
Recommended Display Size
46"-60"
VESA Mounting Interface
200 x 200 mm, up to 600 x 400 mm
Max Load Weight
227 kg
Material
Aluminium
Black powder coat
Wheels Qty
4
Material
Aluminium
Black powder coat
AV Furniture
Cart
Recommended Use
4 flat panels
Shelf Qty
1
Cable Management
46"-60"
Max Load Weight
227 kg
Wheels Qty
4
Wheel Diameter
12.7 cm
Eight-way micro adjustment
Brand: Peerless-AV
Price Range Ex VAT: £1500+
