Large Flat Panel adapter plates (PLP models) are either universally compatible with most large flat panels, or uniquely compatible with one screen make or model. Peerless adapter plates for flat panels allow users to choose between Peerless' wide array of applications and accessories to mount a flat panel virtually anywhere. Most models feature security fasteners for theft resistance
- Peerless PLP PAN65 - mounting component - for flat panel - black
- Product Type
- Mounting component
- Mounting Components
- Adapter plate
- 113 cm x 5.9 cm x 42.9 cm
- 6.9 kg
- Recommended Use
- Flat panel
- Black
- 113 cm
- 5.9 cm
- 42.9 cm
- 6.9 kg
- Black
AV Furniture
- Adapter plate
- Recommended Use
- Flat panel
