Product
Peerless-AV Peerless Universal Flat Wall Mount for 32" to 40" Displays
Reduced Price - Whilst Stocks Last!
Quicklinx: 7MS6WS00 Mfr#: PF640
Type: Mounting kit
Stock Status: Clearance
Hurry, only 1 left in stock!
£26.06 ex VAT
£31.27 inc VAT
Express delivery Order within the next 5 hours for delivery tomorrow
Ideally suited for medium/large LCD screens, the Paramount PF640 flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 30mm away from the wall.
Peerless PARAMOUNT Universal Flat Wall Mount PF640 - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
48.9 cm x 3 cm x 34.9 cm
2 kg
Recommended Use
LCD display
Recommended Display Size
32"-46"
Flat Panel Mount Interface
400 x 300 mm
Max Load Weight
45 kg
Material
Fused epoxy
Gloss black
5 years warranty
48.9 cm
3 cm
34.9 cm
2 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
400 x 300 mm
32"-46"
Max Load Weight
45 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
Price Range Ex VAT: 0 - 50
