Peerless-AV Peerless Security Enclosure for Projector - Black
Quicklinx: 9YYQWS00 Mfr#: PE1120
£506.31 ex VAT
£607.57 inc VAT
Lock in the high level of projector security with the PE1120. Its solid steel construction provides maximum security and is designed to be easily retrofitted to any mount.
  • Anti-theft design
    The PE1120 projector enclosure features an anti-theft design, ensuring your projector is secure and protected in public or high-risk areas. Its robust steel construction adds an extra layer of security against potential tampering or theft.
  • Durable construction
    Crafted from high-quality steel, this enclosure is designed to withstand the rigors of daily use while protecting your projector from scratches and other damage. Its scratch-resistant finish keeps the enclosure looking new, even in busy environments.
  • Versatile placement
    Designed for ceiling mounting, the PE1120 offers flexible placement options, making it an ideal choice for various settings, from classrooms to conference rooms. Its compatibility with ceiling mounts ensures a stable and secure installation.
Peerless PE1120 enclosure - Anti-Theft - for projector - black
Enclosure (Anti-Theft) - ceiling mountable
56.9 cm x 52.1 cm x 31.9 cm
16.1 kg
Recommended Use
Projector
Material
Steel
5-year warranty
56.9 cm
52.1 cm
31.9 cm
16.1 kg
Material
Steel
AV Furniture
Enclosure
Design
Anti-Theft
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Scratch-resistant
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: £500 - £750
